Installing map sensor
I just ordered a 2 bar map sensor and noticed it is alot bigger then the stock map sensor and also has a different style connector. Did I order the wrong sensor? It said it was "GM STYLE" Any advice on the best way to put this in if its the correct one? Also will I need a diff pig tail?
just leave stock one in the intake and tee the vacuum line for the HVAC controls that is what i did
and either buy the adapter harness(highly suggested to make life easier) think FROST sells them? there are a few sponsors here that sell them
or use the plug and switch the two wires when putting harness together.
^^ Yea I had noticed some people using that.. If I knew I had to buy another pig tail too.. I woudl have just bought that if it worked the same.
If anyone has a link to where I can get the adapter harness I would appriciated it.
