intake manifold swap?
I'm pretty sure mine came with all bolts that were required, although they are black and go rusty after some time. I purchased some stainless steel ones to make it looks a little nicer.
read post #4. The bolts are the same, except you use a 10mm on the stock ones and the FAST ones need allen wrenches. You will probably need the hardware kit anyway for the TB bolts and valley cover bolts.
its a little black cardboard box that says fast on it. It has all the little bolts that hold the intake together, the bolts that bolt the intake on, the valley cover bolts and the tb bolts if you order the kit with the tb hardware.
