Power Windows And Radio Aint Working Help.....
i had my electric cutout hooked up with the radio fuse and blew the fuse. so i installed a new 1 and now the fuse block isnt getting power also right above the radio fuse slot is the 30amp fuse for the windows that isnt power either. so i took out the intire fuse bank and to look at the wires from behind just incase something burned or something. the wires are fine, so i starting testing them with a meter and i notice that the window fuse and the radio fuse use the same wall "power" looks like a little wall of power lol anyways ..... i tested all the relays and fuses under the hood on the driverside all good and the grounds as well ???????? plz help
thanks
thanks
thanks
thanks
