do pulleys? yes or no?
ok if i do pulleys will it casue any other things that are belt driven to fail or have problems? does it make anything weaker or run it too fast? if i were to get it what pulleys should i buy and where should i get them from? by what pulleys i mean... alt, crank, and ps pulleys
Re: do pulleys? yes or no?
I would definitely say go with at least the crank pulley and if you can go ahead with the alt. too.Check Thunder Racing and also MTI is getting new shipments today on pulleys I was up there on Saturday so you may wanna call Wayne over at MTI.
The power steering pump seems to be overdriven with the stock pulley, so the only thing you will do with an underdrive pulley is make the pump last longer because the underdrive pulley will spin it slower. These pumps seem to be somewhat prone to failure. I've never noticed a lack of steering boost with my ASP pulley.
Since you have a 6-speed go with the Underdrive crank pulley, and if you have a stock stereo system go with the underdrive alternator pulley too.
If you have a aftermarket stereo drawing alot of power then just get the underdrive crank pulley and NO Alternator pulley.
The Overdrive alternator pulley is for Automatics with big stereos that can't get a full charge, and will cost you some power since it speeds the alternator back up so you get enough charge for your accessories while giving you some of the benefits from the underdriven crank pulley.
I have a 6-speed and have the underdrive crank and alternator pulleys and my car stays right above the red voltage gauge when I have everything on(AC, headlights,radio) and only at idle, while the rest of the time the voltage is normal.
Good Mod!
Good Mod!
