View Poll Results: Would you buy brisk plugs again?
Multiple Choice Poll. Voters: 12. You may not vote on this poll
Brisk LGS Spark Plugs, Revisited...
I dug up some posts regarding these plugs and most of them are a couple of years old. I will be doing a cam swap real soon (a real mild 220 Comp Cam) and I figure I will go ahead and change plugs at that time. I have been running TR55's up until now. I am planning on using the Brisk part number: GOR17LGS since they are supposed to be about the same heat range, and I have will stock a static compression ratio.
Since these have been out in the field for a couple of years now, I would like to hear from a few people that have used them to see if they like them, and if they have held up well. I really don't want to drop a hundred dollars for plugs if they don't last for at least 30K miles.
Here are the specs:
BRISK Premium GOR17LGS Spark Plug, 14mm thread, .708"(18mm) reach, 5/8'(16mm) hex, tapered seat, resistor, LGS Lamborghini semi-surface firing tip design, retracted integrated ground electrodes, silver center electrode. Please visit PLUG MODELS - LGS for more firing tip configuration information.
Here is a link to their site in case you want more info:
http://www.briskusa.com/
Here are the specs:
I peresonally wouldn't spend that type of money on a spark plug. I have a couple of friends that use them in their own builds, but I still can't understand why. I see sparkplugs as a disposable item. Once it gets fouled up, toss it out. I dont know about you, but I can't afford that type of $$ on a disposable item. I stick NGK's. They are readily available, affordable, and seem to be working ok for me.
I agree that they are expensive as far as plugs go, but in terms of the money spent on cars that is a drop in the bucket. I mean they aren't much more expensive than a tank of gas in todays world.
LSX Mechanic
People crack me up with these magical spark plugs that "increase HP and better gas mileage"....
Listen..
I personally have tested every spark plug under the sun in LS1 engines for nearly 10 yrs. Everything from the Bosch +4's, Rapid Fires, spit fires, double platinum, copper, etc etc etc etc...I haven't seen one yet that out performs the plain jane NGK coppers, when correctly matching the heat range to your particular engine.
There is a reason the fastest LS1's in the world don't use these bullshit plugs with all these ridiculous claims. It's because they're, plainly stated.........Bullshit and an easy ploy for taking suckers money.
Good day.
Listen..
Good day.
Listen..
Good day.
Listen..
Good day.
Don't get me wrong, I don't expect to put a set of these in and see a 10hp improvement, but I am curious to learn more about them since they are relatively new. The point is, if everyone had the same "tried and true" attitude, we wouldn't have running water or electricity, and everyone would be driving around in horse drawn carts.
Lots of money is spent in unecessary ways in the name of peformance, lots of people aren't scared to drop a few hundred bucks for fancy airboxes on different vehicles only to gain a slight increase in hp, etc. etc.....
Here's another question, have you ever indexed a plug for better performance? If so then why would you not consider these plugs? In theory, using these plugs would serve the same purpose as indexing the plugs but they would save a lot of time versus indexing plugs while the motor is in the car...
Listen..
Good day.
Listen..
Good day.
If anything go NGK iridium for longevity but the best deal is a tr55.
I offer them for 18.75 delivered to your door.
LSX Mechanic
As Blanco stated, if you want some more longevity and are too lazy to replace your plugs @ the copper intervals, then the Iridiums are fine.
But guys, do not waste your money ($10+ per plug) on these bullshit plugs. You won't feel a damn thing and I'd be willing to bet if you put your car on a dyno and did a before/after, it'd be the same HP or within 1 HP difference between them all.
Put some $2 coppers in there, and change them every 15-30K (depending on your preference and what you do with your car/engine).
When it comes down to the plug you have to consider what is happening. The spark ignites the air fuel mixture. That's IT.
All that matters is that there IS a spark with the minimum energy required to ignite the mixture. That's it. There's no magic to a combustion spark that will produce a more powerful flame.
All you are really paying for between materials is longevity of the plugs.
put in new copper plugs..do some pulls, swap to brisk silver plugs and do more pulls...
every time it has shown gains thru the entire rpm range..
some cars only a few ponies, some cars as much as 8hp
i have some brand new GOR17LGS plugs for sale 50 bucks shipped. i was going to use them when i was NA but cant now with the mods i have...to hot of a plug
