TPS sensor voltage
TPS sensor voltage
Can anyone tell me the specs for a 99 Trans Am A4 TPS sensor Voltage? Also how do I actually test it? I have a nice multimeter to use I just need to know what goes to what. I reset my idle after the cam , and now Im back to stock.I know the IAC controls the idle, but I need to make sure the throttle blade is where its supposed to be. Thanks!
https://ls1tech.com/forums/showthrea...t=mod+bumpstop
The Search function is your friend! Good Luck!
