What does these codes mean?
2000 camaro v6 3800 with 1999 ls1 in it...im trying to diagnose some wiring problems
another question....i have a handheld programmer to check codes and look at real time data and when i look at the real time data it says 14.5 psi on the MAP sensor when not running
does that mean my MAP sensor is bad??? I would think so but i dont know
also if this helps any...the car will only start with WOT or alot of gas and then wont idle....if i hold it steady at about 2000 rpm it will run but very shaky then when i let off it dies....also it is backfiring alot
Location: Your girl's back door giving her the long stroke while you're at work
P1637 Generator L-terminal Circuit
http://gearchatter.com/viewtopic8959...f6e9a6f54b1d6c
P0200 Injector Control Circuit Voltage
http://gearchatter.com/viewtopic9367...cd3e9e09adde76
