SLP LMs vs Borla
SLP LMs vs Borla
looking to switch my stock exhaust for either Borla or SLP Loud Mouths which one these do u guys recommend and which will sound louder but at the same time give me good numbers (HP) and is it tru about SLP Loud Mouths and there back pressure i had a buddy and he had a Z28 with some Borlas and when he took off the passenger side pipe to flow free when he lets off the gas at full trottle he would get these nasty pops my question is do SLPs have it worse than the Borlas and if so how do u guys recommend to fix that also if goin with SLP i noticed u guys say that they sound pretty bad when adding LTs and ORY which ORY and LTs you recommend to run with SLP or Borla
and if none of these then what good exhaust LTs and ORY you recommend for excellent mean sound and good HP AND TRQ numbers appreciate it guys
Re: SLP LMs vs Borla
I gained 33rwhp 24rwtq going from a stock catback to LM and a LID. I think the LM is the best flowing catback out there. I liked the sound of the LM with the stock headers. It sounded good, but when i added the LT's with ORY it became loud, but i still lived with it. Now after adding the cam i couldnt drive the car with the same setup. So I swapped back the cats to lower it a little bit and it sounds good now. If u want to run ur car with ORY and ur car has LT's and cam i dont suggest going with the LM. Im selling mine now and looking for a quite catback so i can run the car without the cats.
If cost is an issue just go with the LM from SLP. Installation was easy and the only issue was my 4" slash tip rubbing my ground effect, but that was an easy fix. Since putting the LM on I have bought Hooker headers W/O cats and I must say damn, I learned the meaning of RASP for christ sakes. But at WOT it sounds mean as hell and everyone who has heard it agrees it sounds MEAN. With LT's and LM I definitely hear those pops you are referring to. If I were you I would go with the LM from SLP. One they cost a lot less. Two you can still add a bullet insert or the CC inserts and quiet them down.
I started out with the LM and loved it nice power gains and sounded awesome too.Now that I have heads/cam/headers and off road Y I switched to Borla because it always you to be quiet or loud.I say that if your going with cam/LT's and off road get a quieter setup-The LM gets raspy when you have LT's and off road Y-I personally like it doesnt bother me at all but if you want no rasp with LT's and off road pipe then go another direction.
lm is way cheaper and louder, but borla is NICE. if you have the pocket book i would say go with borla, it isn't loud all of the time. and lm can get annoying, especially if you want to be quite for some reason
SLP LM for two reason.
1. LM is a lot cheaper.
2. SLP tips (either single slat cut or dual dual) lot 10x better then borla tips.
/end of thread
You'd think for the money that corsa and borla would design some better tips/better looking tips. R&D from those companies sucks.
/end of thread
I have LT and LM , I love it . Guys are constantly asking me what exhaust I have or what motor is in "that thing " .
When you get on it , it's like your at the drags !
I have heard that the LM's don't give enough back pressure though , that you could make more power with some back pressure . Anyone got a reply to that ?
Cause I don't know about that one .
Originally Posted by Tainted
Borla and never look back. Borla has the sexiest tips out there, and its fully stainless steel and adjustable. if it gets to loud, put a smaller plate on it. the lm cant do that and if you ever add heads/cam/lt's youre gonna hate it
Thats R&D right there custom cound.
Borla and Corsa tips don't tuck right. I've never seen a pair that tucks well. They've always hung at an angle.
