Want to Go Faster N/A
i want to go faster n/a but i only have a few things left to do, but out of the things left what will give me the biggest gains
mods:
free mods
slp lid
k&n air filter
slp lid
shanner s3 ported throttle body
ls6 intake manifold
edelbrock long tubes
ory
cut out be for moroso sprial flow muffler
9" 3.90s
42Lb injectors
232/234 cam
i just got some n20 its a dry 78mm plate so a 90/90 is out of the queston. but would a under drive pulley or some type of ram air from fast toys be the best way to go or could i get the bigger lid and maf and i dont think an ewp is for me dont want to spend that much.
mods:
free mods
slp lid
k&n air filter
slp lid
ls6 intake manifold
ory
9" 3.90s
42Lb injectors
232/234 cam
with me its 3675. i went with n20 because the power gains of 150hp for 1300 vs some good tfs heads that gain mab 45 for 2000.
i know a real type of ram air would help and so would a ud pulley but....
so the 85lid and maf would show gains, even thoe its going threw the ported ls1 throttle body and ls6 inkate?
add thoes two things an underdrive pulley and ftra could i see another .4 or 4mph
https://ls1tech.com/forums/dynamometer-results-comparisons/971896-85-mm-lid-maf-gains.html
But here is my thought. If you get a FAST 90/90, why would you keep your stock 75mm MAF and Lid???? To me that would be a bottle neck. Less air getting in.
So it does make sense to get the 85/85 combo. I will be doing that in the next day or so.
I have my home made version of FTRA and i too have an UDP..
But i ahve no test runs with the home made FTRA. But i know a guy with a slightly larger one (he has no A/C) he gaines .2 or 25RWHP with it
I wish i had a 9" with 4.10s
2002 Trans Am M6
Engine
TSP Cam: 228/232 .588/.595 110+4 | MTI Lid | K&N w/Removed Air Silencer | WS6 Lower Air Box | Home Made Ram Air | P&P TB | TB Body By-Pass | Bump Stop Mod | 160 T-Stat | ASP Pulley
Exhaust
QTP LTs | Custom 3" O/R Y Pipe | Flowmaster Merge | GMMG C/B
Driveline
Pro 5.0 | Textralia Z Grip
