Uh Oh
Old 10-12-2008, 10:38 PM
Bmx4Rizzo's Avatar
Default Uh Oh
So i was driving yesterday (01 ws6 a4) and I pulled onto the highway and punched it and around 5k i heard a huge clank clank smash sound, then smoke everywhere (oh ****, right?). So I shut it off and pulled over and take a look. The only thing i see is oil everywhere put no metal. After I pulled it home i get it in the air and take a look. To me it almost looks like the top seal of the filter blew off. SO I change the oil (no metal) and cross my fingers and turn the key, it cranks, no grinding but its not firing. So I am going to guess timing chain? My question is how would I diagnois it wiht out have to pull the cover off? Just pull a wire and see if it is jumping the gap? All help is appreciated-Tim
Old 10-12-2008, 10:56 PM
trailwart's Avatar
do a compression test
Old 10-13-2008, 12:53 AM
Bmx4Rizzo's Avatar
What should it be at? 120ish?
Old 10-13-2008, 01:01 AM
1994Z28Lt1's Avatar
you could also pull a valve cover and see if the valves operate as you turn it over
Old 10-13-2008, 01:12 AM
Bmx4Rizzo's Avatar
Thats what else I was think and is probally the easiest way
Old 10-13-2008, 12:04 PM
Bmx4Rizzo's Avatar
Anyone else?
Old 10-13-2008, 12:10 PM
Lt1Porsche's Avatar
the easiest way is to check and see if the valves operate. through the valve cover.
Old 10-13-2008, 12:12 PM
LS1Tech Sponsor
Rob@EFIAlchemy's Avatar
what he said if your valves open its not your chain
Old 10-16-2008, 03:56 PM
smf_ss's Avatar
That sucks
Old 10-16-2008, 05:18 PM
Red96TA's Avatar
Wouldnt you be able to tell if the timing chain broke by the sound of the engine while cranking? Youd think it would be slowed enormously? Maybe my theory on how motors work is off though. Been a long day
Old 10-16-2008, 06:20 PM
Raise's Avatar
Just curious, as others probably are, as to what brand filter you were using
Old 10-16-2008, 07:06 PM
slowassta's Avatar
if the chain broke, im pretty sure that there are a few bent valves.... but if it is cranking with no odd sounds it would seem the chain is not broke... i think
Old 10-18-2008, 12:07 PM
Bmx4Rizzo's Avatar
Well i pulled a valve cover-valves are opening and closing, no sounds, and it was a wix filter with a little under 3k miles on it...........so i have a warranty so i guess its time to haul it to the shop and have them diagnois it, then get a check, then install the ls6 heads I have and most likely a 233/239 cam with a 3800 stall WOOHOO! Hopefully something good comes from this
Old 10-18-2008, 01:22 PM
blown03mustang's Avatar
from the way it sounds it will definitely be a good thing once you get it back
Old 10-18-2008, 05:48 PM
Bmx4Rizzo's Avatar
you forgot the heads hahaha
Old 10-29-2008, 10:21 PM
Bmx4Rizzo's Avatar
Guess what! Rod sticking out of the side of my block! YAY!
