ATTN ENGINE GURUs WTF CAN CAUSE THIS!?!?
Old 10-14-2008, 04:04 PM
SS4Luck's Avatar
Default ATTN ENGINE GURUs WTF CAN CAUSE THIS!?!?
bout a month ago i thught i blew a head gasket. thought cool, little bit of work and ill be back on the road, but with school starting i didnt have time and took it down to the corvette mechanic where i take my '82 (corvette mikes, for those of you that might know about them)
anyways i get a call from Carl sayin he had some had news it wasnt a head gasket, infact the head gaskets looked perfect, and so did the head and i needed to come down and look....
well this is what waited for me..
and this is why we thought it was a head gasket, after looking at the heads and everything Carl cant figure out where the water was coming from...
Old 10-14-2008, 04:19 PM
ZexGX's Avatar
You're just lucky that NOS didn't blow the welds off of your intake.
Seriously though, that sucks hardcore.
Old 10-14-2008, 04:49 PM
PREDATOR-Z's Avatar
Let me guess, piston #5 and # 7
Old 10-14-2008, 04:52 PM
SS4Luck's Avatar
yea howd u know lol
Old 10-14-2008, 05:10 PM
JDP
JDP's Avatar
Originally Posted by SS4Luck
yea howd u know lol
cause those are the back cylinders and they get more air and go leaner than the front ones.
my number 7 looked like that 2 years ago when my car went lean on spray. your not the first person this has happened to.
time to build a new motor
Old 10-14-2008, 05:12 PM
PREDATOR-Z's Avatar
yea howd u know lol
Been there, not fun, intake design flaw.
Old 10-14-2008, 05:17 PM
SS4Luck's Avatar
*insert sarcastic voice* ******* cool!
anyone have any idea where the water is coming from then?
Old 10-14-2008, 05:21 PM
bongva's Avatar
dang that sucks!
Old 10-14-2008, 06:04 PM
Red96TA's Avatar
looks fun :-)
Old 10-14-2008, 06:16 PM
RsSean's Avatar
well since you have the motor I don't think there is a way to pressure the coolant system to find out where it is come from. How come the tech did not do a pressure test to see where the coolant was coming from in the first place before taking the heads off.
But I was going to ask if you were running boost but someone said it was N20.
Old 10-14-2008, 06:28 PM
SS4Luck's Avatar
the n2o comment was a joke, my car is NA.
When they pulled the plugs cylinder 5 was full of water and i started it right after it happened and it just shot white smoke forever so it was classic head gasket symptoms... until we opened it up
Old 10-14-2008, 06:38 PM
60ftkiller's Avatar
HEEEEY! Thats the exact same thing that happened to my motor, but it was #3,5 and7! **** sucks!
Old 10-14-2008, 06:43 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
its not an intake design flaw.there have been tests where someone put the intake manifold on backwards and the same 2 rear cylinders were still the lean ones.They said it has something to do with the waterjack design right there.
Old 10-14-2008, 07:23 PM
SS4Luck's Avatar
so would that solve the wheres the water coming from problem?
because when we pulled #5 plug it was full of water... like to the brim in the chamber and there was some in #7 too
Old 10-14-2008, 07:46 PM
JPH
JPH's Avatar
Check for the water leak down by the motor mount area. They crack around there. If this was a N/A motor only, you had/have one HORRIBLE tune or 79 octane!
Old 10-14-2008, 07:53 PM
SS4Luck's Avatar
eer id like to think it wasnt the tune.... car put down numbers in sig and ran times to back it up...
and its so cal, u never know what kinda gas your getting
Old 10-14-2008, 07:55 PM
LSX Mechanic
Damian's Avatar
Were u running a FAST intake?
Old 10-14-2008, 07:59 PM
98Camarod's Avatar
You must have had some water in your oil because water doesn't compress. You're lucky you didn't throw a rod.
Old 10-14-2008, 08:17 PM
SS4Luck's Avatar
no it was a stock ls6 intake and there is no water in the oil, at least none on the dipstick
Old 10-14-2008, 08:24 PM
c0ncEpT's Avatar
Are there any visible cracks in the cylinder walls? All I can think of is that maybe there is a hair line crack thats leading right into a water jacket or something along those lines.
