Removing Cylinder Heads with ARP Studs
I need to replace the lifters in my 2002 F-body. I have ARP studs holding my heads down. Can they be removed in the car with the studs? Any tricks?
Ezra
Ezra
Just pull the studs out with an allen wrench before you pull the heads, that way the heads come off very easily.
No need to leave the studs in place and fight with the head, thats how **** gets banged around and nicked up.
Interesting point about avoiding nicks to the sealing surface. But I thought one of the 'extra benefits' about head studs is no coolant gets in the bolt holes of the block. I've never used the studs, I went with ARP bolts due to cost.
LSX Mechanic
Yes the heads will come out no problem. I've done this tons of times in the car, with the studs still in place. Don't worry too much pulling them off and getting any nicks, as your heads should be resurfaced anyway (at least a cleanup pass, .003 or so) before reinstalling.
When you install them back on, if you've never done it before with studs I would have a buddy help you keep the head steady while you slide it down. This will insure you don't booger up the deck surface.
Not bad for TEN year old advice! lol
