Ptv to close?
Old 10-16-2008, 12:20 PM
fauslpss's Avatar
Default Ptv to close?
I have .047 clearance on the exhaust side of the cam.
Old 10-16-2008, 03:19 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
That's a little tight for sure!! What method did you use to test this?
Whats the intake side?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 10-16-2008, 03:42 PM
fauslpss's Avatar
Installed everything and ran it through the sweep with clay. The intake is not as extream of a duration as the exhaust it had enough room. It was .110
Old 10-16-2008, 06:26 PM
Raise's Avatar
Just curious, what are the head and cam specs?
Old 10-16-2008, 06:54 PM
fauslpss's Avatar
Its decked 241's and a 230 242
Old 10-16-2008, 09:00 PM
JPH
JPH's Avatar
measure again! Wat to tight and for you to have safe int clearance, somethings up?
Old 10-17-2008, 08:39 AM
Raise's Avatar
decked how much? stock valve sizes?
Old 10-17-2008, 08:56 AM
fauslpss's Avatar
I checked agian the next morning cam out with the same exhaust I didnt bother checking the intake again. There 59cc chambers stock valve sizes I got the heads from someone on here so I can ask him.
Old 10-17-2008, 09:13 AM
PREDATOR-Z's Avatar
What is your LSA and ICL?
Old 10-17-2008, 09:52 PM
fauslpss's Avatar
Im just going to flycut the piston got a tool from lindy tools great guy to talk to. If you ever need a flycutting tool go to him. Thanks for everyone's help
Eric
