Will a trex or ms3/4 cam fit with 220CC 5.3L STAGE 2.5 CNC PORTED HEADS ?
I have these heads with a torqurer 2 cam right now. I would like to upgrade to the ms3/4 or trex cam. Will either of these cams fit without flycutting ??
With bigger cams the only sure way to tell is to test it out and plan on worst case scenario that you have to flycut.. Hell if you have to flycut at that point I'de mill the heads while I'm already in there and have a more effective setup. But if your budget is so strict that you cant figure in the possibility that you may have to flycutt than you may want to hold off a little while and get some more money behind yah.
LS1Tech Premium Sponsor
We recently finished up our newest camshaft The Texas Tsunami. The Tsunami features custom TSP Lobes on the intake & XER exhaust lobes. The specs are 235/240 .65x/.61x 111. The Tsunami has better p/v than the MS4 & it might clear the cylinder heads your running. I'll do some p/v checking next week & let you know what kind of clearance differences the camshafts have.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
damn TSP, u guys are coming out with a new cam? man, im curious to see the power it will make.
The cams they offer are already as big as you can pretty much go without flycutting if you want to go substantially bigger you would DEFF have to flycutt, but most tuners/engine builders on here will tell you that the MS4 and Trex Ms3 and this new tsunami cam are already big bump sticks.
The issue is going bigger isn't really helping from a power standpoint. We've tested many competitors larger camshafts & several camshafts the Comp Engineers helped us workout for stock 346 applications. In every test the MS4 & Tsunami both showed to be right at the limit of hp gains, in most tests the larger camshafts made equal or less hp & torque while moving the torque peak WAY UP...
Jason
Jason
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
Funny on the Tsunami,
I have a grind that I use
236/240 .617/.610 111+2 LSA, that has produced really good numbers in trq and Hp.
One guy here with a LS6 cam only made 84rwhp and 68rwtq (peak) with it. (from his bolt on setup)
He wanted it Juice friendly so the +2 instead of strait up.
It is a bit tight on intake, but in-line with big cam PTV tolerances.
To the op sorry for the thread hijack
