Degreeing the cam
Old 10-19-2008, 10:53 AM
y2kc5's Avatar
Default Degreeing the cam
I installed my new cam in my 00 c5 without degreeing it.. its a comp cam. custom grind
228/232 on 112 .588/ .595 lift
Installed it dot to dot.. I know i should have degreed it but got carried away putting the car back together before thinking about it. maybe to many beers later lol... Am i leaving alot of h/p on the table without degreeing or should it be real close
Old 10-19-2008, 12:10 PM
JPH
JPH's Avatar
Most custom comps I see DON'T have any advance ground into, but you will be losing some lowend trq and maybe alittle upper rpm power, but with that 112ICL(if ground with 0 advance), this cam will carry peak hp past 6000k now.
Old 10-19-2008, 12:17 PM
y2kc5's Avatar
im going to call comp tmrw they should be able to tell me if it has advance in it right?? Damn i dont want to have to take it all apart again.
Old 10-19-2008, 12:30 PM
JPH
JPH's Avatar
Got the cam card handy?
Old 10-19-2008, 12:42 PM
y2kc5's Avatar
Heres my cam spec per cam card..
valve lift intake .588 ex.595
valve/tim @.050 int 2btdc 46 abdc
ex 48 bbdc 4atdc
These specs are for cam installed @112.0 intake centerline
dur@ .050 in228 ex 232
lobe lift .3469 .3500
lobe sep 112.00
Old 10-19-2008, 12:50 PM
Apollo0526's Avatar
There is no advance, if there was, it would say lobe sep 112 + ...
Old 10-19-2008, 01:43 PM
JPH
JPH's Avatar
ex 48 bbdc 4atdc
lobe sep 112.00
NO advance. 112LDA and 112ICL
Old 10-19-2008, 02:33 PM
mathia's Avatar
Isn't it true that you'd need an adjustable timing gear to add any advance during the install? If you use the stock timing gears, wouldn't moving it a tooth from dot to dot be too much?
My understanding is that degreeing the cam just allows you to verify it was truly ground to specs, but you'd need an adjustable timing gear to adjust the advance.
Old 10-19-2008, 02:35 PM
JPH
JPH's Avatar
Either do it way an adjustable t/c set or offset bushing on the cams dowel pin.
Old 10-19-2008, 02:39 PM
mathia's Avatar
Ahh, cool, I didn't know you could effectively move the dowel pin like that. Makes sense.
Old 10-19-2008, 03:33 PM
y2kc5's Avatar
so do you think ill be happier with this cam advanced 2-4degrees? it a mn6/ 243 heads ls6 intake long tubes/ ud/pulley vararam yada yada 342 gear
Old 10-19-2008, 07:39 PM
JPH
JPH's Avatar
4* imo.
Old 10-19-2008, 08:53 PM
y2kc5's Avatar
Pat g was kind enough to give me his opinion he suggested 2 So off i go to rip it apart again
JPH you were very helpful cant thank you enough Ill be ordering that timing set tmrw
Old 10-19-2008, 09:59 PM
JPH
JPH's Avatar
remember +4 on the crank gear will give you +2 at the cam. Bet you he didin't tell you that? LOL No problem man, anytime.
Old 10-19-2008, 11:15 PM
LLC
LLC's Avatar
Advancing or retarding a cam by crank position is just plain dumb.
