Antisieze on stainlless studs?
Should I still put antisieze on my stainless studs into heads for exhaust manifolds, from my cast manifolds to turbos and from turbos to downpipes. All are stainless studs and think copper nuts and stainless washers.
Kit instructions don't say anything about antisieze but figured might be good idea? Or can it let parts loosen up when you don't want them to?
General rule of thumb: Use anti seize on:
Stainless to stainless connections,
Stainless to aluminum connections,
Aluminum to aluminum connections.
Basically anytime you are mating two non-ferrous materials you have the potential of galling/seizing and should use anti seize.
Also use it on bolts and connections that come into contact with high heat sources.
