I am pretty sure the heads will bolt to the block (fit) but the valve covers won't and you will have to get the coil brackets for the ignition coils to bolt to.
Yes they will fit. As mentioned above the valvecovers are the only difference in bolt pattern/design. You will need to covert over to a center-bolt valvecover and coil bracket setup when you switch to the 243's.
