Need HELP Ring and Pinion ASP
Hellow people.. im despert for help i have 2002 A4 corvette with ratio 2.7 i just ordered motive gear ring and pinion ratio 3.72, and my mechanic says it does not fit n i need a spacer !! i found one here but they says its for camaros only.. Can any plz help here wheere can i find spacers for corvette online ?!! any links any idea`s i would be very thankfull..
i do not believe there are any spacers available out there for the corvette differentials.
unfortunately, in your case, i think your only choice is to go with an entirely new diff if you want to change the gear ratio.
You need a 3 series carrier to fit your 3.73 gears. If you have a manual trans with any kind of power, you can shear the bolts off. It can be done, but I never recommend this to my customers as in the long run the damage is not worth doing it right the first time. I've even seen the bolts sheer off from a firm shifting auto trans. What is your peace of mind worth? Good Luck.
