ADVICE NEEDED: 3.905 vs. 3.910 Head Gaskets?
Old 10-23-2008, 04:22 AM
IGNANt's Avatar
Exclamation ADVICE NEEDED: 3.905 vs. 3.910 Head Gaskets?
I was told to go with Cometic gaskets for my setup and I found a couple: 3.905/.045 and 3.910/.040. .040 is the stock thickness right? but the stock bore is 3.905? Id like to know which one would be right for my setup and why:
-LS1 Block
-249/254-.617/.619-112lsa
-Polished GM Crank
-Probe UltraLight 6.125" Forged I-Beam Rods
-Ross 3.905 Forged Pistons -4cc
-Total Seal Advanced Profiling Rings
-200 shot plate system
Old 10-23-2008, 10:53 AM
JPH
JPH's Avatar
What does your combustion chamber measure across the head?
Old 10-23-2008, 11:51 AM
smask04C5's Avatar
Stock bore is 99mm, which is 3.8976. I used 3.910 Cometics .040 thick as you described. Stock head gaskets are approximately .056 compressed.
Old 10-23-2008, 12:33 PM
UNDER PRESSURE MOD
The Alchemist's Avatar
The difference in diameter is only 0.005" which is only 0.0025" at each side of the bore. I don't think that it would make much difference, I say go with the tighter quench, thinner gasket as well.
Old 10-23-2008, 12:47 PM
CW 99 Z's Avatar
I would run the 3.910 bore gaskets. You dont want the gasket the exact same size as the bore. Esp on ls motors where the piston is out of the deck.
Old 10-23-2008, 01:10 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
It really wouldn't make any difference on 99.5% of the builds on this site. We stock the 3.910" bore gaskets from Cometic at competitive prices. Let us know if we can help!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 10-23-2008, 03:08 PM
Gary Z's Avatar
My recollection is that the stock LS1 gasket diameter is approximately 3.940 inch - it is definitely greater than 3.910 inch.
Old 10-23-2008, 03:52 PM
vettenuts's Avatar
You need to know chamber width and taper width on the top of the bore. Then you need to get the fire ring about 0.030" outside. I say none of the above until more information is provided.
Old 10-23-2008, 08:14 PM
JPH
JPH's Avatar
You should have just quoted me Bob? LOL
Old 10-24-2008, 12:14 AM
PREDATOR-Z's Avatar
Yes, aggreed with Vettenuts and JPH, and there is also another thing you need to check, you PISTON DECK HEIGHT. It is an aftermarket block, pistons could be .010 out and with .040 could be too tight a quench at .020, then you might need thicker gaskets.
Find out what is your piston position in/out of hole, then make your decision .030 circle bigger than your bore.
Old 10-24-2008, 01:54 AM
IGNANt's Avatar
its a stock block with an aftermarket forged rotating assembly, the heads are 853 casting milled to 62cc.
Old 10-24-2008, 04:13 AM
PREDATOR-Z's Avatar
Ask who built it what is your piston deck height. If it is you, then measure it.
Quick Reply: ADVICE NEEDED: 3.905 vs. 3.910 Head Gaskets?
