Will I have a balancing issue?
I have a LQ4 block and crank which were supposed to be used together with Mahle dished pistons and Eagle H-beam rods.
Pistons weigh same as originals (435g) but the h-beam rods are 28 grams heavier than originals (640g vs. 612g). Does this lead to expensive heavy metal balancing job?
Yes, of course it needs to be re-balanced, but question is, doesyhe stock crank need heavy metal inserts or not?
Please, you that have stock crank and heavier than stock rods, tell me about your balancing experiences!
