engine ticking - LS1TECH
engine ticking
Thread Tools Search this Thread
Old 10-27-2008, 07:09 PM   #1
coryprine's Avatar
Default engine ticking
i posted in general help but i was hoping for a lil more help... 2 days ago the camaro started ticking on cold start up and went away when it warmed up... today it does it constantly... wont go away and increases in rapidness and loudness as i press the pedal
i tried seafoaming it tonight and changing to a lighter oil... nothing... no change.... wtf is going on?
coryprine is offline   Reply With Quote
Old 10-27-2008, 08:18 PM   #2
01screaminchickin's Avatar
10w-30 ams-oil synthetic, my car did the same, i was running 5w-30 mobile one syn. and it would start doing that on a cold start after about 2000 miles, royal purple 1250 miles, ams-oil i have 5000 on it with no hydraulic lifter tick
01screaminchickin is offline   Reply With Quote
Old 10-27-2008, 08:23 PM   #3
coryprine's Avatar
i hope that does it... im just worried b/c most say the lifters quiet down after warm up... mine does it at any temp and just gets faster and louder with the rpm's
Old 10-27-2008, 08:30 PM   #4
Golf&GM's Avatar
Do you have headers? Exhaust leaks will tick and the tick will get faster with RPM. They also sometimes go away when the gasket gets hot and expands a little. Easy way to check is to listen and put your hand over the header/manifold where it sounds like it's ticking and see if you feel a "put-put-put" of air against your hand.
Golf&GM is offline   Reply With Quote
Old 10-27-2008, 08:33 PM   #5
coryprine's Avatar
nope car is bone stock
Old 10-28-2008, 04:03 PM   #6
02BLACKTAWS6's Avatar
Does it kinda sound like a sewing machine?
02BLACKTAWS6 is offline   Reply With Quote
Old 10-28-2008, 05:12 PM   #7
coryprine's Avatar
its a steady ticking at idle and increases in rapidness when revving
Old 10-28-2008, 06:12 PM   #8
Golf&GM's Avatar
I've had this problem a couple different times and it had a couple different solutions. Even if you have the stock manifolds check for an exhaust leak to rule that out.
The other time I had a loose rocker arm, I could put my hand on the valve cover and feel a pretty solid ticking where the arm was hitting up against it. If you can feel something, or if it sounds like it's coming from under there you might want to pull the valve covers and make sure everything is how it should be.
If you've ruled out those two then use your ear as best you can to try to find out where the ticking is coming from and then go from there.
Old 10-28-2008, 06:14 PM   #9
It might be the lifters too. GM is famous for it. No big deal though. Just annoying.
Old 10-28-2008, 07:06 PM   #10
coryprine's Avatar
ok i think ive gone nuts... i spent the last 2 hrs with a screwdriver to my damned ear.... not a sound from the valve covers... it seems to be louder under the car near the starter area.....
a year ago i replaced my starter and when i took the old one out the aluminum nose piece was broken off... inside the housing i am assuming.... COULD this be what i am hearing.... wouldnt it be loose and rattling rather than one place and increasing in tapping when i rev..... help me guys im at a loss..... like i said... it appears lounder underneath....
Old 11-06-2008, 10:46 PM   #11
blklime02's Avatar
DAM! i have the same problem..so if its the lifters its not a big deal???
blklime02 is offline   Reply With Quote
Old 11-07-2008, 08:16 AM   #12
Go check for exhaust leaks. I just had my cat blow out the flange welds where it connects to the manifolds. Sounded like a lifter tick untill it finally blew all the way out.
kmspruill242 is offline   Reply With Quote
Old 11-07-2008, 08:41 AM   #13
GM WORLD CLASS's Avatar
your sure it's not a knock instead of a tick? You may be over examining piston slap. Every ls motor eventually gets it and it varies characteristics. If all is running ok I then I wouldn't sweat it.
GM WORLD CLASS is offline   Reply With Quote
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
