Interesting rockers....
Re: Interesting rockers....
Correct me if I'm wrong, but they look like Jesels to me? and there individually adjustable as opposed to te Yella's these are great for the solid roller guys.
They are the new Comp Cam LS1 shaft mounted adjustable 1.7 rockers,DRE makes them for CompCams.I bought a set to try out,suppose to fit under stock valve cover.
I just found out that to use these rockers....
1) You need custom pushrods or have yours machined
2) The pushrod holes need to be enlarged
#2 I can live with but getting custom pushrods made for the LS1...How much is that gonna cost?
Phillip
Phillip
Ok,these will more than likely require machine work to open pushrod hole,.090 towards Ex.side,I was told some do and some dont but if the head is off ,why take a chance.
As far as custom length pushrods,the rockers have .050 of adjustability.Lets say you run Comp R lifters that like .010 pre load or less,that would leave .040 to adjust for pushrod length or am I missing something?
naa, just use the dremel yo.. ;D
[Disclamer: Vents does not condone the use of a "dremel" on any part of the LS1 engine, doing so could be detremnental towards the engine and other components. do so at your own risk.]
good looking rockers though, if they were more like 3 ish, i'd consider them over the Jessels or a T&D set.
I should have mine soon and will let Jay[AbsoluteSpeed]try the fitment on his test motor.I will let you know what Jay comes up with.
Phil,that is one short pushrod[7.050],do you know how he came up with a 3/10s inch shorter pushrod?
I hope this set up dont turn into a $500+ pile of crap.Live and learn.
The angle of the cup for the push rod is all wrong. I really tried everything to get them right, but couldn’t. I’d be interested to see how you go with them.
It’s a shame really, because they are a very nice thing to look at. I’ve used T&D’s, Yella Terra, both Comp Cams types including these and Crane 1.8’s.
So far, the T&D’s have been the most flexible product for all variations of spring diameters and install heights.
Good luck and please let us know how you go.
Pete.
Pete.
