lifter change
pull the heads then pull the lifters...pretty straight forward
http://www.ls1howto.com/index.php?article=3
Read that...it will help you out with pulling the heads
Very simple once you have the heads off. The lifters sit in little trays that sit in the block. There are 4 lifters per tray, and 2 trays on each side of the motor. There is one 8mm bolt securing each tray to the block. Once you have the bolts out, pull the trays out and the lifters just pull right out of the trays. A few of the lifters might want to stay in the block, but you can pull them out pretty easily
It's not too bad. Just take a weekend so you aren't in a rush. You will have to remove the heads for the swap. Use the link posted above for LS1HowTo as your guide. It is a great source for information. You will also need to pick up new head bolts and head gaskets for the install. Let us know if you need anything or have any questions!
Jon Reynolds
Texas Speed & Perf.
Jon Reynolds
Texas Speed & Perf.
