Cam help
Old 10-31-2008, 12:07 PM
crapyboy750's Avatar
Default Cam help
Ever since i have had my cam installed and tuned every day is different on how the way it drives what could be causing this? Either it drives perfect one day and the next it could be riding and bucking like its going to die.
Old 10-31-2008, 12:11 PM
razorclaw99's Avatar
tune most likely..either that or maybe you have an o2 sensor going out..Are you throwing any codes? I mean it could kind of be anything really
Old 10-31-2008, 12:22 PM
But i dont understand how the car can drive perfectly fine one day and then the next it can drive like **** under the same conditions. No codes and the 02 are new.
00SSLS1's Avatar
specs of cam and list of mods?
Old 10-31-2008, 12:23 PM
00SSLS1's Avatar
weather changes?
In my fquick
Old 10-31-2008, 12:24 PM
weather changes?
Nope i was driving around the other night and it was alot colder than it is now.
Old 10-31-2008, 01:06 PM
SOMbitch's Avatar
A lazy o2 will act like this. Mine had one right after the H/C install but not quite to the extreme you describe. Swap a new one in or get your tuner to read it for you.
Old 10-31-2008, 05:28 PM
Have someone check out your o2's with a scanner..
