Instructions with ARP Main Studs
Does anyone have the guidelines/ instructions that came with their main studs? If so, could you post them up or send them to me?
I bought some used ones off here and just want to make sure I install them right. Thanks
ARP Main Stud Kit Installation Method
Part Number 234-5608 for GenIII/LS Series Small Block
Screw the studs into the block "HAND TIGHT ONLY"
Preload (Torque) Recommendations with ARP Moly Lubricant
Follow the manufacturers recommended torque sequence.
Inner Studs - 4.770 long 60 ft lbs.
Outer Studs - 4.550 long 50 ft lbs.
Side Bolts - 20 ft lbs. (use RTV sealant under the head of the bolt)
Windage Tray Nuts - 28 ft lbs.
When changing from factory to high strength fasteners, you should check main bearing bores and align hone if necessary.
