p0122 help
Old 11-01-2008, 10:12 AM
Ricky_GD's Avatar
Default p0122 help
Ok here's the story, i have a ls1 in a GD cobra kitcar running stock pcm and im having some over fueling issues ( which i might have sorted) but also some idle problems, i have removed the PCV valve which helped alot but im still getting p0122 throttle pedal position sensor/switch a circuit low input.
while i was modifying the wiring loom i removed EVAP and all the wires that i do not need and accidentally pulled the 5v reference wire a little so it wasn't in the connector properly, so i put it back in and it now seems to work ( i can tell becuase im getting a TP reading on my auto logic scanner ) but im still getting the code, i have read that you need to reset the TPS to zero but i have a cutoff switch on the car so all power gets cut to the pcm at night ( doing this should reset it right?) also the wiring loom had a connector with some TPS wires in it i dont know what these are for ? but the 5v reference t-s into it and has the same colour wires that go to the TPS.
Anyone know what this could be?
Thanks
Old 11-02-2008, 11:07 AM
got-a-ls1's Avatar
just wondering why are you cutting power to the pcm every night? your probably making things harder on yourself with the computer having to relearn fuel trims and such. I know whenever my battery is out of mycar for a couple days my car starts and runs like **** until it relearns.
also resetting the tps basically means re adjusting it so it reads the corect value 0% when the throttle is closed. Ive never done it though so there may be more to it.
Old 11-02-2008, 04:04 PM
Ricky_GD's Avatar
its a simple cartek cutoff switch used for when im on the track in case of a electrical fault, i can press the button and cut all power from the battery, if you do not press the button when the car isnt being used then it slowly drains the battery, i have now decided to leave it on and just use a trickle charger, i will measure the voltage and see whats what! thanks
Quick Reply: p0122 help
