Couple of Spring questions
Old 09-17-2003, 01:14 PM
WicketMike's Avatar
Default Couple of Spring questions
Right now i have a 222/224 114 .574 cam
im not sure what springs i have
how long will the springs last about?
and what are the best springs to get with this cam and if its time to change the springs what else should i change at the sametime?
thanks
Old 09-17-2003, 04:48 PM
WicketMike's Avatar
Default Re: Couple of Spring questions
i probably have a good 10,000 miles in my current springs that where put in at the sametime as the cam. do you think its time to put some new ones in?
Old 09-17-2003, 04:59 PM
jrp
SN95 Director
jrp's Avatar
you put in the springs and dont know what kind they were ?
spring life depends on a alot of things but in your case with 10k miles on the springs you dont know about i'd replace them just for peace of mind.
some comps 918's would be fine, there good for .600 lift. i went with rev duals myself.
Old 09-17-2003, 05:02 PM
jrp
SN95 Director
jrp's Avatar
while your in there you could freshin it up with some tit. retainers and valve seats, and valve seals if you'd like.
Old 09-17-2003, 07:15 PM
WicketMike's Avatar
somebody else installed the springs, but i remember them being the 918's
i remember him saying that the first ones he put in broke in the first 1/2 hour after starting it up because of the problem they where having with those comp springs. then we got the ones with the stripes
Old 09-18-2003, 01:00 PM
robertbartsch's Avatar
...i would avoid comp springs for that reason ..they also have had more than one bad batch; right?
Old 09-18-2003, 07:34 PM
WicketMike's Avatar
what other springs is there to use? and where can i get them?
right now i have the cam i listed above. i plan i going to some stage II heads and a bigger cam soon. what springs will do for what i have now and the future plans
thanks
Old 09-18-2003, 11:40 PM
soundengineer's Avatar
manley springs
get 'em thru MTI------------------------------>
Old 09-19-2003, 12:00 PM
WicketMike's Avatar
manley springs
thanks!
Old 09-19-2003, 12:16 PM
WicketMike's Avatar
i just checked out the MTI site and saw the springs. it says they work with stock heads.
I plan on getting some LS6 stage II heads soon, will they work ok with those heads also?
Old 09-20-2003, 11:04 AM
when you buy heads just tell them what you have and they will come with springs/retainers/new valves already installed on them...and tell them you want duals if you can get em.
If you're gonna do the heads soon...then jsut wait till you get the heads....no sense in doing work for nothing
