Engine temp stays 190+ no matter what
Just curious if this is normal...I have Ford Windstar cooling fans that were enough to cool my 350 to 160 or so in a hurry when I turn them both on, but I've found with the ls1 even running down the road at a low rpm cruise with both on in 40 degree weather the temp won't go lower than 190 and usually hangs around 194
Just want to know if there's anything I should check or maybe the sensor is a "dummy" type that just reads cold, warm, and hot or something. Engine is a 98 but sensor and harness are for a 2000
the stock thermostat is insane. I had 207 degrees all the time with the stocker. I changed for a 160 thermostat and it never sees 180 unless pushing it. I can't run a mid-engined car that will see track time with normal temps at 207.
