TR 224, 400rwhp?
224/224 .563 cam, the TR cam is better
407rwhp full bolt on and a light flywheel. 3.90 gears
stage-2 LS6 heads ported TB, LGM headers, pulley, 6 spd, Ti mufflers(2003 vette)
Judging by your sig, longtubes should be your first order of business. I'd go underdrive pulley, ported MAF ends, and either a set of PRC's Terminator heads or some AFR 205s. Should put you over 400 rwhp for sure.
EDIT: Don't forget a nice dynotune with this round of mods as well.
2002 Camaro SS M6
224/230 .581/.588 114lsa
ASP pulley
SLP lid
Ported TB
Jet-Hot headers
Bassani exhaust
400rwhp/373rwtq
It has come a long way since then. I think that was in '06 when I had that setup.
ASP pulley
SLP lid
Ported TB
Jet-Hot headers
Bassani exhaust
400rwhp/373rwtq
UNDER PRESSURE MOD
Back in 2002'ish, I put down 427/401 with and ls6 intake, stock maf, throttle body, mail order tune, MAC headers, and a crushed ypipe (literally, it was 2.5" pipe that was bend on a normal bender). The graph below is comparing that setup to my previous setup which was poorly ported heads and a 216 cam.
So with my current setup, I've swtiched to QTP's, a custom tune, FAST 90/90 and added bigger injectors, I should be safely around 450/415.
