tv 2 cam..what do shift at?
just wondering what people with the TSP torquer 2 cam are shifting at going down the track. my mph seems kinda low to me and i am wondering if i am shifting to high or if my gear is to steep. i shift right when my factory tach reads 7 so i am guessing i am right around 67-6800 rpm. i also have 4.56 gears and run on 10.5 x 27 qtps. going through the traps my tach reads about 72-7300 in 4th gear. i'm thinking i have a little to much gear. i don't really want to do a 28" tall tire either. my mph is only 114 115 when i should be around 118. i am not to worried about mph but let me know what you think
when i had mine i was shiffting it at 6500 cause thats wear it peaked at coulda got a couple more hundred but i didnt think it was safe on the stock block with older rod bolts and my trap on motor was the same as yours i was runing stock 243 cast heads with 40 mill gaskets hope it helps
Yeah I shift around 6500 too. In my case with a stock bottom end on a 112 + 4 degrees of advance ground in there is no need to shift higher than that . Peak HP is at 6000 for me.
It sounds like you have a little too low of a gear IMHO. Have you ever scanned or logged it to see what your RPMs are really at?
with my v2 i was shifting at at 67-6800 and was getting around 112.5mph.I lowered my shift points to around 64-6500 and i get 114.8 mph now and occasion 115.xx I am cam only in my car though.
i am told i had ported 5.3 heads. i do know they are 5.3 heads for sure though because of the casting numbers. thats basically what i get is 114-115 but if i had good heads...SHOULD be 117-119. alot of people cam only run the same mph as i do but i they seem to hit low 12's as i hit high 11's
No they're dynojet so I guess if you have mustang #s yours are a good bit stronger. It was 100.6 degrees in the shop the day I had it dynoed though I guess my numbers will be lower now that I have a 9 inch...time for some more go fast goodies! And finally time to take it back to the track since I don't have to worry about breaking the 10 bolt!
