What is this sound?
Old 11-05-2008, 07:29 PM
dubrado's Avatar
Default What is this sound? *video included*
It's not a pulley, tensioner, or belt...checked and triple checked. It makes the sound w/no belt on it.
It's loudest on start up and after I run it hard. Over a few minutes it quiets down but is still there, just at a quieter sound level.
It sounds like it's coming from under the passenger side head/intake manifold
Old 11-05-2008, 07:33 PM
TireSm0ke's Avatar
check your rocker arms and pushrods
Old 11-05-2008, 07:36 PM
conan's Avatar
What he said ^^^ and might want to drain your oil and see if there is metal in it and also if its smells burnt.
Old 11-05-2008, 07:44 PM
dubrado's Avatar
Pushrods are fine, and rockers are fine.
Old 11-05-2008, 09:30 PM
dubrado's Avatar
Could it be a lifter or maybe even transmission related? I have an auto w/stall
Old 11-05-2008, 09:38 PM
Restricted User
2001 Pewter WS6's Avatar
Not your transmission....
Old 11-05-2008, 09:51 PM
Gregorya24's Avatar
lifter........
Old 11-05-2008, 11:00 PM
wbwhiteboy's Avatar
did you just recently put the stall in the tranny?? Cause not all aftermarket stalls will just bolt in. sometimes you have to put spacers between the bolt and the flywheel, cause the bolt holes on the stall isnt deep enough for the stock bolts. which makes ur stall rattle.
Old 11-06-2008, 12:50 AM
fortmyerspolice's Avatar
sounds like more than one lifter
Old 11-06-2008, 10:11 PM
dubrado's Avatar
I thought a bad lifter would make more of a tick sound, not a squeak/chirp
Old 11-07-2008, 05:33 PM
dubrado's Avatar
Gonna buy a stethescope and see if I can get more specific on the location.
Old 11-07-2008, 11:32 PM
OUTLAWZ RACING's Avatar
Take your assceory belt and start the car could be pullies. Any codes or mis fires?
Old 11-08-2008, 06:10 AM
dubrado's Avatar
tried it already, it still makes the sound w/no belts on it
No codes, haven't logged it for misfires though.
Old 11-08-2008, 08:20 PM
IRONFIST's Avatar
My car made that noise for a few days... then a lifter gave out.
