Can stock 97-98 806 heads bolt to a 4.8L with not valve clearance issues?
Old 11-05-2008, 08:29 PM
turbotacoma's Avatar
Default Can stock 97-98 806 heads bolt to a 4.8L with not valve clearance issues?
I have some one that I know who is in a bind. I have a set of 97-98 heads that are ready to bolt on (gaskets and All). He was wondering if my 98 heads will bolt on to his 4.8L with out any valve clearance issues to the bore. I have looked and haven't found an answer to this ?
Need Help!
Thanks
Old 11-06-2008, 08:38 PM
blackLS1m6's Avatar
Yes they will work but you will lose compression. You will need to use 97-98 valve covers and coil pack brackets.
Old 11-07-2008, 12:46 AM
LSX Mechanic
Damian's Avatar
As stated above they will work, but it will probably hurt the truck's power a little bit due to the drop in compression.
He/she will also have to purchase 98 valve covers, and find some way to rig up your coils. 98 heads require each coil to be bolted individually to the cover, and a truck coil won't bolt up.
Not worth the trouble IMO.
Old 11-08-2008, 01:37 PM
thanks guys and I do have the valve covers to go with it. I figued the coiul packs would be an issue. We'll have to work around that. Again thanks
Old 11-09-2008, 07:45 PM
blackLS1m6's Avatar
No problem good luck!
Quick Reply: Can stock 97-98 806 heads bolt to a 4.8L with not valve clearance issues?
