Cam To Big????
Old 09-18-2003, 07:27 PM
NA$TY-TA's Avatar
Default Cam To Big????
Im am working on building a iron block 370ci and i am trying to decide on a cam. When the new motor goes togeather it will have stage II heads w/ 2.055 and 1.60 valves. It will be Lunati Pro billit rods and forged 4.030 pistons, and a stock crank good for runiing 15 lbs of boost.
The cam im looking at is a 232/238 .585/.585 114+3 LSA. Would that be to big for the 370? How about stock heads w/ comp 918's ?? Will i have a problem with piston to valve clearance?? Spinning to 6500.
Thanks
Old 09-18-2003, 10:47 PM
2001CamaroGuy's Avatar
Default Re: Cam To Big????
nope.....the G5X-2 cam is larger than that and people (soon to be also) are running it on stock short block 346s.....
Old 09-18-2003, 11:08 PM
jmX
jmX's Avatar
As long as your shortblock has flycut pistons you should be fine with piston to valve clearance.
Old 09-19-2003, 10:04 AM
NA$TY-TA's Avatar
So one of you says yes and the other says no. I dont have fly cut pistons on my 346, but on my 370 i will. So should i wait and just install it on the 370?? That cam should work well with FI right??
Thanks
Kyle
Old 09-19-2003, 10:33 AM
2 yes it will work (even in the 346) and 0 no it wont....
Old 09-19-2003, 01:24 PM
NA$TY-TA's Avatar
Thanks guys. It will go in, in a while then ill pull it when my 370 goes in. Thanks
Kyle
