what do 5.3 heads need to be milled to make 11:5 compression?
Old 11-08-2008, 06:44 PM
wmcfa's Avatar
Default what do 5.3 heads need to be milled to make 11:5 compression?
I have some 5.3 heads and would like to see 11:5 compression how much milling will that require to reach that compression?
Old 11-08-2008, 08:35 PM
MrElectric03's Avatar
My comp is about 11.2:1 with no milling on my PRCs and .045" Cometic head gaskets.
Old 11-09-2008, 02:05 AM
ZMONSTER!'s Avatar
Im running about that milled .030. I think Im at 11.4 with the GM gaskets.
Old 11-09-2008, 05:27 AM
Thimble's Avatar
Lots of variables involved...
If nothing's been done to the heads (not ported), the 61cc 5.3 heads with a .040" gasket will land you right at 11.5 unmilled.
With a GM MLS gasket, you'd be 11.0-11.1, and would want to mill about .015" to get to 11.5.
Porting these heads and unshrouding larger valves usually enlarges the chamber size a couple cc, so they are typically more like 63cc in modded form. So you might need to mill .010-.015" or so to make up for that.
You should start this process using a compression calculator, and by choosing your head gaskets. Enter all the fixed data (bore,stroke, piston type, deck height, etc) into the calculator, then start playing with chamber size and gasket thickness variables until you arrive at your desired CR. Then (if your heads are not stock), have your chambers cc'd (actually measured), and then you'll know how much to mill to achieve your desired chamber size.
I had mine milled .025" to 59cc, and am also using a .040" gasket. With -1cc notch cut out of the pistons, I'm at 11.67:1.
Old 11-09-2008, 07:36 AM
VR_GTS's Avatar
With the head / gaskets you have, would i need to fly cut with a 224r cam?
Old 11-09-2008, 08:56 AM
White.Lightning's Avatar
I'm running the Stage 2.5 5.3L heads, 63cc, unmilled
Gasket is a Cometic 0.040", Cam is a 230/236 612/600 111 installed straight up, Stock 346c.i. w/ 91k miles
I didn't flycut the pistons or mill heads and am running 11.17 SCR and 8.43 DCR
Old 11-09-2008, 09:10 AM
sroach20's Avatar
what engine?
Old 11-09-2008, 09:12 AM
Originally Posted by sroach20
what engine?
Old 11-09-2008, 02:11 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Using a compression ratio calculator is the way to go. You can plug in different dynamic variables as in head gasket compressed thickness and combustion chamber size to get different numbers. Then, roughly .007 milled off of a head = 1cc of combustion chamber material removed.
Quick Reply: what do 5.3 heads need to be milled to make 11:5 compression?
