AFR 205s, ported FAST92, 232/234 ?
Old 11-09-2008, 07:02 AM
camarorat's Avatar
Default AFR 205s, ported FAST92, 232/234 ?
Anyone runnig this combo? Stock botom end, AFR 205 @59cc, Ported FAST 92, 92MM TB, and cam in the area of 230/234, .505/.598 114lsa and usual bolt ons. I am contemplating this package and was wondering what kind of HP/Tq and 1/4 mile times you are turning.
Old 11-09-2008, 07:07 AM
teke184's Avatar
assumin you had the PTV clearance right....should produce well.
my guess would be 450rwhp/415# torque
Old 11-09-2008, 11:43 AM
SUCK MY SS's Avatar
by any chance do you mean .605 lift on the intake lobe?
and is it 232 or 230 degrees duration on the intake?
Old 11-09-2008, 12:15 PM
IRONFIST's Avatar
Yah that must be a typo???
Old 11-09-2008, 12:35 PM
Skeet Skeet's Avatar
Ill bet that will make some serious power! good luck with the build
Old 11-09-2008, 02:40 PM
camarorat's Avatar
Yep, should be .595 on the intake. No typo on the duration, I know the F14 and some others are 232/234, and that's OK Just wanted to here from some folks that are running something close to those cam specs.
Old 11-09-2008, 05:57 PM
Phil'sC5vette's Avatar
was thinking 460 RWHP
Old 11-10-2008, 03:43 AM
chieftransam's Avatar
I have a 230/234 .612/.598 112 custom cam. I made over 400 to the wheels. I don't remember the exact amount, nor do I have the Dyno sheet. I moved overseas and it got misplaced. I'm on a ls1 intake rather than a ls6 or in your case a FAST 92/92 setup, plus I'm using Patriot LS6 59cc heads rather than AFR's and on the stock bottem end. I was on more of a budget at the time, and now I'm saving for a stroker, but you will make good power. The cam I have is great, it pulls hard!
Old 11-10-2008, 10:40 PM
WS6Jim's Avatar
That should shine in the numbers and at the top end. 450 sounds like a good number assuming the motor itself has life in it. Just make sure you have all the other boltons and go to town.
Old 11-10-2008, 11:54 PM
pdd
pdd's Avatar
my setup is close. 228 cam, 90mm ported and afr 205's and put down 450rwhp
Old 11-10-2008, 11:58 PM
Restricted User
socmguy's Avatar
That setup will make SICK power. I have a friend with that setup but a 224/228 cam. It's a monster from idle to WOT!!!!
