LQ9/LQ4 Forged Motor Strength
Old 11-11-2008, 02:07 AM
sf35thle's Avatar
Default LQ9/LQ4 Forged Motor Strength
How strong and reliable are the LQ9 6.0 Iron Block motor and are they worth using for a N/A setup. I searched and couldn't find much, how much HP can a forged 6.0 take, Thanks
Some internals,
Scat Scat 4340 LS1 4.000 crank 24 tooth reluctor
Scat 4340 LS1 I-Beam 6.125 Part # 2-ICR6125-7/16
Wiseco K464F3 LS1 3cc Pistons 4.030 Bore
I am just debating be the LQ4/LQ9 and LS2
Any help is welcomed
Old 11-11-2008, 03:07 PM
427's Avatar
The iron or aluminum block can handle all the power you can make NA with no problem. These engine blocks will surprise you with what they will handle in basic stock form.
Kurt
Old 11-11-2008, 09:43 PM
da_shadow's Avatar
ill go with the lq9 or 4 its the same.......iron is the way to go...forget about weight...you put that scat stroker on it and try to break it
Quick Reply: LQ9/LQ4 Forged Motor Strength
