1000 dollars heads?
1000 dollars heads?
im looking at patriot stage 2 ls6 heads and a 226/226 .585 .585 112 lsa comp cam. hoping for 430 rwhp horse in an m6 car, already has ls6 intake, lid, lt's, ory, smooth bellow.
anybody know if prc or any other company makes a head similar to this for cheaper than 1350 loaded like the patriot?
please dont flame, just lookin for info, if you know it i would be glad to learn it.
That said, TSP stage 2.5 ported 5.3 heads are a great deal, but if you have the cash, by all means go AFR or TFS. He could probably get really close to his goals with just the TSP heads.
Well, depends on how much he has/wants to spend. Yeah AFRs are going to kick *** compared to a ported GM casting, but they are almost 1000 bucks more of a "real-er head" lol.
In cylinder heads, you get what you pay for, but if the goal is only 430 rwhp through an M6, then yes, even the TSP heads can get you there with a decent sized cam.
Peak flow numbers don't tell the whole story about a cylinder head though. The only tool we really have to tell how well a head works is the dyno. (Thanks Bret)
well they flow 257 cfm even at .400".
they flow almost as well at .300" (208cfm) as a stock truck casting does at .500" (219cfm) and they have nice 220cc ports, 2.02valves and a small chamber.
I think with a nice cam like a tv3 or ms3 he would see 400whp
I've never seen these heads with a good cam, they always have a MS cam under them. But from what I've seen so far I'd still get the Darts or just put a bone stock set of 243's with the valves lapped on it.
Yeah he would see 400 with the MS3 but he could also see 400 with stock 243's. I guess the reall guestion for the OP is does he want a dyno # of 430 or does he want the car to run at the track?
Here's a custom cam on a M6 with 421rwhp and a mean *** torque curve.
https://ls1tech.com/forums/dynamomet...o-results.html
It's a little shy of 430rwhp, but then you could save that $1,000 and put it towards your suspension (what good is 420rwhp if you can't hook); or save up for some nice heads. I like the ETP215 set ~$2,400.
If 430rwhp is your only goal don't even bother with heads.
PRC heads will do just fine. It's obvious some of the people in this thread hate PRC. Hey KMS.1320 why don't you and willyfastz go suck bret's dick together, with your biased opinions.
whoa whoa whoa! I'm going to have to report that personal attack.. no need to get hostile!
