Did a cam swap. How much end play should there be?
Old 11-16-2008, 06:21 PM
ele-blue95's Avatar
Default Did a cam swap. How much end play should there be?
Im putting my motor back together. Today I put in the new cam and timing set. Then I noticed the cam had about .100 of end play in and out, is that normal for a 6.0L block. The original timing chain broke. So im doing a head/cam swap. I have the retainer plate TQ to spec and the new dual timing set in place. Any help would be great.
Thanks, Eric
Old 11-16-2008, 07:07 PM
vettenuts's Avatar
Could be one of three things.
1. Mis-machined cam such that the undercut on the cam is too deep.
2. Worn cam retainer plate, inspect both sides (although this would be a lot of wear).
3. Mis-machined/wrong upper timing sprocket.
If you mount the stock sprocket, does the clearance problem go away?
Old 11-16-2008, 07:17 PM
ele-blue95's Avatar
I have checked the retainer plate, its seems to be in good shape.
The timing sprocket that was on the car is an aftermarket comp cam single, the one i just installed is a Rollmaster Dual. I have not put the comp one back on to check.
Comp Cams cut the Custom cam for me this last week. How deep should the under cut be?
Old 11-17-2008, 09:31 AM
ele-blue95's Avatar
alright guys! I found the problem, the cam gear was not tightened all the way down. Thats what I get for stoping and going to dinner with some friends Thanks for all the help.
