Edelbrock ls1 2 piece timing cover
Old 11-19-2008, 01:22 PM
youguessit's Avatar
Default Edelbrock ls1 2 piece timing cover
Well i have an 02 camaro and wondering how good the edelbrock timing cover works with a double roller timing chain with the shimmed out oil pump. Anyone with any experience with witht the edelbrock lemme know. I have called and asked several places and nobody knows. its like edelbrock is taboo or somin....
Old 11-20-2008, 12:02 AM
youguessit's Avatar
Cool
so i e-mailed edelbrock because god forbid they answer the durn phone. I recieve a automated return e-mail telling me they will reply to my e-mail in the order of recieved e-mails which means it could be a while i guess. I asked them the question above and told them if they didnt know the answer to send me a cover free and ill find out for them lol Anyways ill update as soon as i find anything out.
Old 11-20-2008, 10:07 PM
youguessit's Avatar
LOl, still no reply from edelbrock. I was told by g-force that for a ms3 camshaft i only need a single roller timing chain. I will probably just go with that then. I am still curious if edelbrock will ever get back to me. The guy at g-force told me that when dealing with edelbrock if your on hold for only an hour your luck is good.
Old 11-21-2008, 04:28 PM
youguessit's Avatar
Exclamation Their reply
So i checked my mail just now and what do you know edelbrock finally replied. They said a double timing chain would not fit under their cover and that their was not "adaquate" material for clearancing. So the answer is Freakin no. While that was dissapointing i found out from g-force that a single roller timing chain would be adaquate for a ms3 cam so i will just go with the single.
Old 11-21-2008, 04:29 PM
00 black ss's Avatar
ls2 chain works just fine. you can find one for about $90 for the whole set. correct me if im wrong?
Old 11-21-2008, 04:38 PM
tim99ws6's Avatar
just buy the chain, you dont need anything else, unless your sprocket is jacked up.
$20 or so for the chain.
Old 11-21-2008, 09:25 PM
Redlinez's Avatar
^ is what I did as well.
Old 11-22-2008, 09:45 AM
youguessit's Avatar
I already have the ls2 timing chain... maybe i will just leave it and port my oil pump myself.
Old 11-23-2008, 08:58 PM
TJ
TJ's Avatar
makes no sense to make a cover that wont clear a double chain.
Old 11-23-2008, 09:02 PM
GrannySShifting's Avatar
Will not clear melling oil pump either, and likely not a shimmed out sto ck pump
Old 11-23-2008, 10:47 PM
youguessit's Avatar
Yeah i have to give it to edelbrock that was a tard move.
Old 11-23-2008, 11:51 PM
the_merv's Avatar
A melling Oil Pump is different than the stock one? It didn't look different to me when I put mine in..
Old 11-23-2008, 11:57 PM
Revelation Z28's Avatar
i dont get they they make a 2 piece when you have to remove both to get either sprockets off anyways to do the cam and pump.
Old 11-24-2008, 03:33 AM
the_merv's Avatar
I'm pretty sure you can get that Cam Gear out of there to pull the Cam..otherwise they wouldn't have made it.
I agree though, I would change the Oil Pump while I was there..
Old 11-24-2008, 05:42 AM
redtail2426's Avatar
What are you talking about???Edelcrap is some good stuff,i mean thay make intakes that dont fit under hoods,covers that dont fit over oil pumps and chains,and the best.......Semi-cnc heads.Edelbrock is a complete joke when it comes to lsx parts.
Old 12-07-2008, 01:50 PM
vsocks1's Avatar
Is there a two piece cover that clears a Melling oil pump and a Cloyes adjustable single timing chain?
Old 12-07-2008, 07:50 PM
TJ
TJ's Avatar
i can hook you up with a qtp setup at a DEAL if interested. i actually have a qtp pump as well.
Old 12-08-2008, 09:10 PM
vsocks1's Avatar
PM me the price/details of the QTP deal!
Old 12-11-2008, 09:58 AM
tim99ws6's Avatar
My edelbrock intake/elbow/tb clears the stock hood? And their cover DOES fit over oil pumps, just not aftermarket pumps, or aftermarket chains.
Old 12-19-2008, 11:07 PM
gromero's Avatar
Gents, I'm currently going through the same issue trying to fir the 2 piece cover over a dual Cloys chain and a melling high flow pump. I've grinded both the bolts on the pump and the inside cover as well an nearly there. I going to try and add a second gasket to get clearance. I'll let you know...
Someone suggested putting the stock cover or change the pump to stock and grind as well but that will be me next step.
Quick Reply: Edelbrock ls1 2 piece timing cover
