How much better are floating wrist pins vs press fit?
personly i think press are better for street mannered cars. I have never seen a pin come loose on a pressed application. but they are a pain if you dont have a tourch and hydrolic press, plus they have alittle more friction. floating are better as far as racing go, because they have less friction. they are easier to install, but i have seen locks on floaters come off alote.
The bigger question is whether you trust the stock rod for what you're doing. I'd disagree with spiralox coming out a lot. Every performance engine sold today with forged pistons and H beams uses them and you don't see a mass hysteria about them.
Different application, but my last GSXR had floating wrist pins with c-clips. I think one of them came loose and completely destroyed the motor. For that reason I'm no longer a fan of floating wrist pins.
C-clips are much different than spiro-locks. Yes, I have heard of and seen c-clips fail, but have never heard of a spiro-lock failing. In fact, just trying to remove spiro-locks is next to impossible without a special cutter type tool. Back to the topic, I'd agree that floaters are marginally better than press fit, but I wouldn't worry too much about it. I didn't when I bought a set of Scat rods and Speed-Pro forged pistons which are press fit!
I think spiro locks are better/safer, I've actuallly installed and removed those before. IIRC they are simple to remove. All you need is a sharp pick to get them started then work them around.
