6.0 lq4 milling stock 317 heads for higher compression?
well heres the deal i have a lq4 6.0l with 317 aluminum heads?
question is how much can i mill/shave the heads for more compression and be safe?
I have a cam specs are- xr-288 hr
lift- in-580 ex-590
dur - in-288 ex-294
236-242@050
i think 112 lsa?
also got 7.4 comp pushrods and gmpp racing lifters patriot dual gold valve springs other than that thats it!
this is going in a 78 chevy luv rat rod/drag truck i want all the compression i can get also might run 150 nos i have later on oh and its carburated 750 holley with victor jr intake and headers
lift- in-580 ex-590
dur - in-288 ex-294
236-242@050
i think 112 lsa?
You will need to measure your current p/v clearance [unmilled] and decide how much you can mill without compromising the p/v clearance . Minimum is .080'' Intake / .100'' exhaust .
You could swap the 317's for LS2 243's and gain quite a bit of compression without milling .
317 = 70-71cc
243 = 64-65cc
317 = 70-71cc
243 = 64-65cc
thanks for the reply this is my first post. I am kinda on a budget so different heads are out of the question at the moment lol. i have a friend that runs a machine shop who is gonna do the work on my heads.
whats the best/easiest way to measure piston to valve clearence? i already have heads off the motor?
Yes use a micrometer to measure the thickness of the putty. You can also use a tootsie roll still in the wrapper, easier to do because the tootsie is harder and the paper is wax lined. The thickness is your clearance.
