This might be a dumb Question!!!!!
You need a hydraulic press and a special fixture to remove the stock wrist pins. If you intend to reinstall the original pistons and rods you should not need to separate them.
Ok, I spun a rod bearing on cyl 7. So I took all the pistons out and forgot to number them. Is that going to be a problem? Also should I get new rods? The pistons seem to be fine. Just get new wrist pins, rods, bearings, rings, and crank and I should be fine right?
If you want peace of mind then go ahead and replace whatever you feel needs it. I'd personally take the parts of concern to a reputable engine building shop/machinist in your area and have them inspect them. You could possibly have the rods reconditioned and the crank ground or polished.
