What heads can I run with the MS4?
I don't want to flycut the pistons, am I stuck with the PRC stage 1 LS6 heads, or can I run the stage 2.5 LS6 heads if I throw thicker head gaskets on? Or do the thick head gaskets defeat the purpose of the 2.5 heads? Only reason I dont want to flycut is because of the 150 shot, I want as much material on the pistons as I can get, I dont need any self-cooling pistons with holes in them. Or are there any other heads on the market I can run?
Thanks in advance.
Thanks in advance.
Unmilled TFS 215s. The revised Valve angle should give alittle more PTV clearance. You might also be able to have the TFS slightly milled. But I would ask a tech from TFS about that to be sure.
Restricted User
this is the same situation I was in. I wanted to run the 2.5 head from PRC but the MS4 limits the head choices. I'm probably going to wind up doing a 5.3 stg 2.5 with the Torquer V.3
LS1Tech Premium Sponsor
For the MS4 you can only run the PRC Stage 1 LS6 heads, or the aftermarket castings such as AFR or TrickFlow. We can get you setup with any of these heads at competitive prices and have the tech experience to go along with the sale so you're not led the wrong direction too
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
For some reason, the 2.00" valve on those 5.3L heads KILLS the flow. We've tried it and never went back again. I liked the theory on paper since you'd get the compression from the 5.3L head, without piston to valve issues. But no-go
__________________
I've done heads by putting 2.02 (stock seats) Vs 2.00 and all I gained was ~5>7 cfm average at various lifts.
Not sure why really. Jason did extensive testing on valve size testing in our various cylinder heads and he said he was very unhappy with that 2.00" valve in the 5.3L head, so we never have offered that valve in this head because of it.
__________________
What about the new PRC 215 head that TSP has coming out soon. I think it has 61cc chambers with stock PTVC. I would wait for these IMO. I think I read ETA for X-mas.
Yes, they like the other aftermarket castings listed will offer more P to V clearance than the stock head setup!
__________________
Yes, they are an aftermarket casting and would work as well.
__________________
