Question about ARP head studs in car & head removal
i think the issue is that you have to remove the nuts from the studs, then remove some of the rear studs.
since there isn't enough room to lift the heads over the studs under the cowl.
not a big issue from what i've heard. and the install with studs is supposed to be MUCH easier.
