do i need to change my valve springs?
i have a 02 trans am with a torquer v.3 cam and i know the lift is really high on the cam and the valve spring only last bout 15,000 miles with that cam.....and lately i the car idles at lower rpm than usual.....and seems not as powerful is this the valvle springs going out......i may be completely off sorry im a newbie just looking for some help
I would expect them to be fine. The lower idle wouldn't be caused by valve springs and you would see a significant drop in power up top if you were having a valve float issue. If you get a chance, you might pull a couple off and have seat pressures are if you have a local machine shop that could check them. If you just want to replace them, I can get you setup on a set of springs only if you would like. Let me know if you have any questions!
Thanks!
Jon
Thanks!
Jon
