tsp 408
Old 11-25-2008, 10:42 AM
BIGB4015's Avatar
Default tsp 408
What kind of power could I expect from this combo?This would be through a m6.
Tsp 408 (iron block)
11.5-1 cr
PRC stage 3 243
TSP giant stick (248/254)
1 3/4 LT Catless
Slp lm1 exaust
Ported Fast 92
92mm t.b
ud pulley
Slp 85mm maf
Old 11-25-2008, 11:21 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
11.5-1 cr
PRC stage 3 243
1 3/4 LT Catless
Slp lm1 exaust
Ported Fast 92
92mm t.b
ud pulley
Slp 85mm maf
We engine dyno'd a very similar setup for a customer recently. I can't find the graphs, but remember it did 623hp at the crank and just shy of 590ftlbs of torque. It was setup to 11.3:1 static compression. Hope that helps!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 11-25-2008, 11:34 AM
BIGB4015's Avatar
Wow that was more than I expected! I was thinking around 550 flywheel hp.How much more does the iron block weigh than the alum ls1?
Old 11-25-2008, 11:46 AM
The iron blocks are about 75-80lbs heavier than the LS1 aluminum blocks.
__________________
