Largest Hydraulic XE-R grind
Formerly 4mulaJoe
So who is running the largest XE-R hydraulic roller cam or one with similar ramps? What does your valvetrain setup look like and what are your results?
Re: Largest Hydraulic XE-R grind
Good info once again, but from my understanding, thats not a complete chart there j-rod. i've got a 238 ex (non XER) lobe on my cam, and it's not shown. hrmm.. mark @ comp was telling me for some odd reason that the biggest lobe they had was a 242 at the time. perhaps this is a later chart, or i was just mis-informed.
D(irecto)r Pepper
Call 1-800 cam help to talk to CC and get the newest info.
Man that chart is old, i had it on my web page for years.
Good luck Joe
6600 rpm clutch dump of death Administrator
I have a buddy @ Comp sending me the master Lobe Catalog. I will try to scan the appropriate sections and post them up.
i have a 236/238 601/605 on a 111 with 2* advance. stock lifters and combinations new ex-616 springs(stock bottom end). still working out tranny and converter issues, but the valvetrain is holding up fine and is not too loud either. we will be checking spring pressures after we switch from the 5.7 heads to the 5.3 heads. after we put the 400 tranny in, we can work on some more solid numbers
OMG on a 116 lsa? that thing is gonna peak WAY high!
