Streetable cam
Old 11-26-2008, 09:13 AM
00firehawk's Avatar
Default Streetable cam
i AM CURRENTLY HAVEING SOMEWORKDONEON MY HAWK. I AM INSTALLING LS6 HEADS,LS6INTAKE / TB, AND A CAM. I WAS ORIGINALLY GOING WITH A 232/224 BUT WAS OFFER A OPTION TO GO WITH A 246/232. I WANT TOGO WITH THE BIGGER BUT WAS WOUNDERING IF ANYONE HAS EXPERIENCE WITH A 246CAM AND HOW IS IT FOR DRIVING ON THE STREET? THE CAR ISN'T A DD BUT DOES SEE A GOOD BIT OF ROAD TRIP AND INTERSTATE DRIVING. PLEASE SHARE YOUR EXPERIENCES OR KNOWLEGE ON THIS
Old 11-26-2008, 09:22 AM
PREDATOR-Z's Avatar
Too BIIIIIIIIIIIIIIG
Old 11-26-2008, 09:28 AM
ThirdGenLS1's Avatar
agree way to big, and not to mention thats a terrible cam.
Old 11-26-2008, 10:11 AM
Restricted User
willyfastz's Avatar
Run from both those cams as fast as you can.
Old 11-26-2008, 10:15 AM
00SSLS1's Avatar
the text?
Old 11-26-2008, 10:16 AM
Vindicated346's Avatar
yeah Im with pred z and the rest of the gang..you wont be happy with that cam..MAYBE something in the 230/234 range..
Old 11-26-2008, 10:50 AM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
I'd be thinking something like 228/228. I like the smaller cams but you could go a little bigger like the others mention.
Old 11-26-2008, 10:53 AM
00firehawk's Avatar
They are both a custom grind from thunder racing. I want something big but small enough for driving. Is the 230/234 a reverse lift cam?
Old 11-26-2008, 11:08 AM
00firehawk's Avatar
Here is a bit more info on whats being done: Ls6 heads, 11 angle valve grind, othe misc. Head work, ls6 intake / tb, ls7 lifters, ls6 oil pump, double roller timing chain, kooks lt headers 1-3/4.
I want a good cam for this set up. I also want a decent "lope" if possible and still be able to drive it around without too many issues. It will be getting a good dyno/tune also to get it all right.
Cams are my weakness when it come to knowledge
Old 11-26-2008, 11:26 AM
TXZ28LS1's Avatar
do u mean the TR 230/224 cam? if so, its a good street cam, thats proven itself so many times.
Old 11-26-2008, 11:32 AM
dankl's Avatar
I agree with all the posts. Both those cams don't look too good at first glance. I'd talk to someone who knows more about cam selection and custom grinds. Personally, on a stock bottom end, I'd avoid going over mid 230's. 228R or a custom 232/234 if you want bigger...IMO
Old 11-26-2008, 03:08 PM
VIPERBLUELX's Avatar
Take it from someone who's been there and done that, don't put a reverse split cam in it.
Old 11-26-2008, 03:13 PM
00firehawk's Avatar
what exactly is the diffrence with a " reverse split" cam?
Old 11-26-2008, 03:34 PM
Detoxx03's Avatar
I'd go with something like a 228/230 or 230/232 from Futral Motorsports or check out the torquer 2.
Old 11-26-2008, 03:45 PM
00firehawk's Avatar
I'm pretty bias..... I only deal with thunder racing, i've been treated like **** at futral. I'll probably call and talk to shane @ thunder it.
Old 11-26-2008, 03:54 PM
Super Speed's Avatar
I'd stay away from those cams as well...
Old 11-26-2008, 03:59 PM
Jedi Master
Gh0st's Avatar
Cams. Avoid you will.
Old 11-26-2008, 04:10 PM
Banned Village Idiot
LS1BLKSS's Avatar
the MS3 is big but still streetable!!
Old 11-26-2008, 04:15 PM
00firehawk's Avatar
"MS3" ? Not familiar, can I get a better explination?
Old 11-26-2008, 04:20 PM
00SSLS1's Avatar
Item Detail
Name:
Texas Speed Magic Stick 3 Camshaft
Item#:
25-MS3
TSP XS Series Camshaft:
Magic Stick V.3 237/242 .603/.609" Camshaft With Your Choice of Lobe Seperation.
The Magic Stick V3 camshaft is Texas Speed's premier LS1 camshaft! This camshaft has gone as fast as 10.50s n/a with stock heads in our 98 Z28 test car.
This camshaft features Comp Cams XER lobes! The XER lobes have been proven to make big horsepower & torque thanks to their aggressive ramp rates & healthy lift.
2300-6800 RPM Power Band with a peak around 6400rpm; This is an excellent performance camshaft with a rough idle! Custom tuning required
