New Cam
New Cam
I'm in the process of building a bracket car. I'm installing a custom cam 247/251 .623 113+3 along with 215cc Trickflow heads. Your feedback would be appreciated.
CoopZ06
CoopZ06
Attached is a list of mods that are being installed on the car. Please post your thoughts. We plan on spinning the motor to 7200K.
CoopZ06
TrickFlow 215cc CNCd heads - decked for 12.0 compression
PRC Gold Valve Spings (good for .650 lift)
Custon Cam - 247/251 .623/.623 113+3
Calles Forged Rods
42LB Injectors
ARP rod bolts
COMP Hi Performance Lifters
Yella Terra 1.7 Roller Rockers
Diamond forged Pistons (with valve reliefs)
American Racing 1 7/8 LT with bullet turndowns
Melling Oil Pump
NA 347 Motor
Vengance Ported 92mm Intake and TB
Custom Ram Air
Other Mods - Turbo 400 RMVB
Precision Shifter
Custom 10Pt Cro-Moly Cage
Kirkey Race Seat & 6pt Harness
Grant Quick Release Steering Wheel
Strange Front & Rear Drag Brakes
Billet Specialities Drag Wheels (Front & Rear)
S60 with 35 spline axles & spool (4.11 gears)
MT ET Fronts (26x4.5) & Rear (28X10.5)
QA1 Shocks - All four corners
Yank 4500 Stall
Custom Driveshaft
Full Suspension Mods.
CoopZ06
Calles Forged Rods
42LB Injectors
ARP rod bolts
Melling Oil Pump
NA 347 Motor
Custom Ram Air
Precision Shifter
Yank 4500 Stall
Custom Driveshaft
It does seem a little large (mainly on the intake side), but those TFS heads flow great and the guys over @ Vengeance have put together some nice combinations, so I would trust him.
Here's some other well-performing "big" cams for reference:
240/244 .605/.596 112 lsa- Vindicator
242/248 .608/.612 110 lsa- TRex
239/251 .570/.570 106 lsa- GM Cup Cam
Your cam isn't much bigger than either of these
Please post your reasons for why you believe this cam is too big for the application. I would appreciate your feedback. Please note, I'm a novice in the technical application of cam specifications
CoopZ06
CoopZ06
