what pushrod length??
i measured my pushrond lenght with Comp Cams Adjustable Pushrod Checker
and got 7.362 intake and 7.382 exhaust with .075 preload. what size should i get?
https://ls1tech.com/forums/7957678-post2.html
do the numbers sound wrong to you?maybe i did it wrong,
i have the polluter cam and PRC ls6 heads with ls7 lifters
That will then give you:
7.375-7.362= .013 variance
add to .075 preload> .075+.013= .088 Intake preload
7.375-7.382= -(.007)
Add that to preload> .075 + (-.007)= .068 Exhaust preload
both fit in the desired range
Is this a cam only swap?
If those measurements are correct, then 7.375 pushrod.
specs are 242/244, .610/.612 and the PRC Stage 1.0 LS6 CNC Ported Heads with PRC Double Spring Kit
